Select element by Spline intersect
can someone please explain what the heaven is going on here?
this is a simple graph yet I cant figure it out! want to rename my rooms based on a spline which was possible in dynamo 1.3 but now in 2 it is not possible. any ideas? thanks
Lacing issue maybe?
the result is still null
hi
just keep in mind that the spline have an elevation of zero when you draw it on view, just check if the room started from zero also to the above level. because if not it will never intersected
the spline is on 0, same as the rooms, should I elevate the spline?
I did and it’s still null
i think you cant, but for test try to make the room start from minus value like -100
I elevated the spline and the result is the same
can you show the output for all nodes?
Anybody?? Nobody?? :frowning:
where can i find the node Select Elements By Spline Intersects?
I think it might’ve been a custom node they made themselves.
Might be worth having a look into this post for some guidance on how to achieve it yourself.
Synthezise toolkit have one if i remember right :wink: but guess do it with ootb is easy as well…just find your element location draw the spline use closest point to and a parameter at point and sort by key
