Select BuiltIn Parameter Group not available in Revit 2023
I have a Dyanmo script which works in Revit 2022. However, once I open the script in 2023, I get an error which states that one of the nodes don’t exist in Dynamo itself (even though it should be an inate lookup node). I posted a picture of the node down below. Is it possible to exchange the node for a node in 2023, because I can’t seem to find it? It’s supposed to be a Select BuiltIn Parameter Group node.
Hi @sai-lok.ly,
In Revit 2023, use instead the Group Types and Spec Types nodes.
The Revit API changed. Parameter Group and Parameter Type were replaced by Autodesk Platform Service data types.
