Search for doortypes with API
I`m trying to collect all doortypes in a revit document with the code below which was provided by archi lab. How can I adapt this code to only return the doortypes in the document an not the instances?
Help is appreciated! :slightly_smiling_face:
Wouter Hilhorst
Version:0.9 StartHTML:00000097 EndHTML:00004306 StartFragment:00000199 EndFragment:00004268 # Copyright© 2017, Konrad K Sobon
@arch_laboratory, http://archi-lab.net
Import RevitAPI
clr.AddReference(“RevitAPI”)
import System
from System import Array
import sys
pyt_path = r’C:\Program Files (x86)\IronPython 2.7\Lib’
sys.path.append(pyt_path)
TypeName=
try:
errorReport = None
#cat_list = [BuiltInCategory.OST_Rooms, BuiltInCategory.OST_Walls, BuiltInCategory.OST_Windows, BuiltInCategory.OST_Doors]
cat_list = [BuiltInCategory.OST_Doors]
typed_list = ListBuiltInCategory
filter = ElementMulticategoryFilter(typed_list)
output = FilteredElementCollector(doc).WherePasses(filter).ToElements()
except:
if error occurs anywhere in the process catch it
import traceback
errorReport = traceback.format_exc()
Assign your output to the OUT variable
if None == errorReport:
#TypeName.append(str(ViewType.get_Parameter(BuiltInParameter.SYMBOL_NAME_PARAM).AsString()))
OUT = output[0]
OUT = errorReport
Hi @wouter.hilhorst,
One possible way to collect door types:
clr.AddReference("RevitAPI")
category = UnwrapElement(IN[0])
doortype = FilteredElementCollector(doc).OfCategoryId(category.Id).WhereElementIsElementType().ToElements()
OUT= doortype
doortype
Thanks!
