Question about revit API
Hello, I am trying to progress by relying on existing documents
and the video:
Why do I get 3 empty list before the family instance ?
here is the code used:
# Charger les bibliothèques DesignScript et Standard Python
import sys
clr.AddReference('RevitAPI')
clr.AddReference('System')
#You'll also want to import the below namespace to get access
#to the ISelectionFilter interface
family = UnwrapElement(IN[0])
family_type_ids = family.GetFamilySymbolIds()
family_instances = []
for family_type_id in family_type_ids:
	family_instance_filter = FamilyInstanceFilter(doc, family_type_id)
	elements = FilteredElementCollector(doc).WherePasses(family_instance_filter).ToElements()
	family_instances.append(elements)
OUT = family_instances
Cordially
christian.stan
Hi Christian,
Because you have 3 out of 4 family types in your family without instances.
Thank you Mr. Alban, I understood, I perceive the filtering better
Cordially
christian.stan
