Filter Element Collector
I am trying to make a collector in python that collects all elements placed in model. I am using doors for this. Is there a way to get all doors placed instead of all placed doors and family types in the model?
#Import Revit Nodes
# Import RevitAPI
clr.AddReference("RevitAPI")
#Filtered Element Collector
collector = FilteredElementCollector(doc)
#Quick Filter
filter = ElementCategoryFilter(BuiltInCategory.OST_Doors)
doors = collector.WherePasses(filter).ToElements()
OUT = doors
04_02.rvt (2.4 MB)
Have a look at this bit of code from @solamour’s DynamoPython repository:
Note that there are several additional bits to this filter which you aren’t using (by view, of class), but they’re good to know about.
The specific part you need is the not element type method - .WhereElementIsNotElementType()
There is also the opposite if you leave out the word Not from it.
Thank you very much!
Regarding the FilteredElementCollector I can really recommend this page:
