Script to over write crop view region line thicknesses
Hi all, attempting to write a script that would change the crop region line weights of elevation views to a new thickness.
What I have here gives no errors, but doesnt work and the last node has a null result. Can anyone help?
As a bit of an update I changed the thickness to something stupid and suddenly the nulls are gone
Here is the error
Hi @lr-PAYNE dont think we have lineweight 122…and thats what the warning try to tell…does it work with genius loci…
Hi @lr-PAYNE try also feeding your “List.GetItemAtIndex” node into the ViewSetElementOverides node.
Failing that use Rythm’s “View.SetElementProjectionLineweight” node.
Cheers KS
Thanks to you both @Kai @sovitek
@sovitek I understand that the max number for line thickness is alot less than what I had in that second post. I was just changing things around to see if I could get a different result which may or may not be relevant to the problem.
OK…the issue here is as i assume the view set override is from genius loci in that case try this one here…here is the difference…
Thanks again to you both. I tried both and this has made it work
Could I enquire what packages were used for this?
