why this code not runnig ? I use cpython3 and civil 3d 2022
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
dataEnteringNode = IN
# Inputs from Dynamo
alignment_name = IN[0]
sample_line_group_name = IN[1]
surface_name = IN[2]
section_view_style_name = IN[3]
# Setup document and editor
editor = adoc.Editor
civilDoc = CivilApplication.ActiveDocument
created_views = []
with adoc.LockDocument():
db = adoc.Database
tm = db.TransactionManager
tr = tm.StartTransaction()
try:
# Get alignment
alignment = None
for id in civilDoc.AlignmentCollection:
a = tr.GetObject(id, OpenMode.ForRead)
if a.Name == alignment_name:
alignment = a
break
if alignment is None:
raise Exception("Alignment not found")
# Get sample line group
slg_id = None
for gid in alignment.GetSampleLineGroupIds():
g = tr.GetObject(gid, OpenMode.ForRead)
if g.Name == sample_line_group_name:
slg_id = gid
break
if slg_id is None:
raise Exception("Sample Line Group not found")
sl_group = tr.GetObject(slg_id, OpenMode.ForRead)
# Get surface
surface = civilDoc.GetSurfaceByName(surface_name)
if surface is None:
raise Exception("Surface not found")
# Get section view style
styles = civilDoc.Styles.SectionViewStyles
style_id = ObjectId.Null
for sid in styles.GetSectionViewStyleIds():
s = tr.GetObject(sid, OpenMode.ForRead)
if s.Name == section_view_style_name:
style_id = sid
break
if style_id.IsNull:
raise Exception("Section View Style not found")
# Create section views at origin (or change insertion point logic)
for sl_id in sl_group.GetSampleLineIds():
sample_line = tr.GetObject(sl_id, OpenMode.ForRead)
for section_id in sample_line.GetSectionIds():
section = tr.GetObject(section_id, OpenMode.ForRead)
if section.SurfaceId != surface.ObjectId:
continue
view_id = SectionView.Create(section.ObjectId, style_id, Point3d(0, 0, 0))
view = tr.GetObject(view_id, OpenMode.ForWrite)
created_views.append(view.Name)
tr.Commit()
except Exception as e:
OUT = f"Error: {str(e)}"
finally:
tr.Dispose()
if 'OUT' not in locals():
OUT = created_views
