Scopeif vs scopeif+
I have been struggling almost all day because the scopif node OOTB doesn’t work correctly, lucky clockwork has made a replacement named scopeif+.
The OOTB node set all nodes before scopeif to NULL and passes trough somehow in my case a “search value” from String.Replace.
Cheers,
What is your input for the ‘test’ in each of these?
Hi @jacob.small,
String This is the true result
At first i did try with the IF node and this didn’t work either now i tried it again and tada it does work.
You want the input of the ‘test’ to be a Boolean (a true or false value), not a string. See the dictionary for more info.
https://dictionary.dynamobim.com/#/Core/Logic/Action/If
@jacob.small,
No
I want to compare if the test value is the same as the true value in this case a string.
and it works with “IF”.
I tried to recreate the error with the “IF” node as i mentioned before but i think it was due to memory and that a restart clears the memory or something.
Thanks.
How about this?
That’s not how it works though. While you’re getting good results now it could be an issue someday (think nested lists and such).
As a result I recommend using an == node to test if they two are the same, and feeding the resulting boolean to the test input in the if node.
