Hi, I have some issue with this graph. I followed everything with what @GavinCrump shared in his youtube channel but sadly there is an error with ExportToExcel node. Just 1 error. May I know what is I missing?
Can’t see your data to confirm, but it appears that your filepath input is a number, but needs to be a string to a valid file path. Double check the input setup.
Put a watch node on canvas to review the content of the data flowing into the path input, as it indicates this is an issue.
When you run the graph, are you selecting a file path?
yes I did
