Get Sorting Parameters From a Schedule
Hello all,
I am trying to get the parameters used for sorting a schedule. I have gotten close but I cannot figure out how to expose the Autodesk.Revit.DB.SceduleSortGroupField. I am not seeing a method in the API to get at it. API section can be found here:
Any help would be greatly appreciated. Thank you,
clr.AddReference("RevitAPI")
scheduleView = UnwrapElement(IN[0])
param = []
for sv in scheduleView:
	definition = sv.Definition
	scheduleParameters = ScheduleDefinition.GetSortGroupFields(definition)
	param.append(scheduleParameters)
OUT = param
Does this help in anyway?
param = []
	param.append([definition.GetField(i.FieldId).GetName() for i in scheduleParameters])
OUT = param
You can also invoke ParameterId instead of GetName() to work with the parameter. In fact, GetSortGroupFields gives you ScheduleFields used for sorting/grouping.
Thank you so much Hadbirad,
I am going to dig in and figure out what you did but that solved my problem.
