Hi
I got som .stp fil which i converted to dwgs and imported into Dynamo. I scaled it in 3D autocad . I created an item in the file to se to compair them when scaling i Dynamo. The result is the .stp converted geomerty did not enter Dynamo size wise as the geometry created in 3D autocad. I have no way to refernece and scale fix the .stp file geometry. Can i have som help? what should I do?
Could be any one of 100,000 things, and with the info given I can’t tell where the issue is. Post the dwg, stp, and dyn files (if you can’t post to the forum then use a web link).
Ok
The stp file comes from this webpage but i allreade convertered it in the attachment
https://www.thecrosbygroup.com/resources/cad-data/
Rovhook5.4.dwg (3.2 MB)
Import geo2.dyn (17.6 KB)
Ok
