Udo
1
The attached Dynamo script creates AutoCAD solids from pipes. This works as expected with Civil 3D 2021, but in 2022 I just don’t get any solids but also no error messages.
The original code is from here:
https://knowledge.autodesk.com/search-result/caas/simplecontent/content/dynamo-4-civil-3d-extract-pipenetwork-solids-pproperty-sets.html
I’m a Dynamo novice, so I’d appreciate your suggestions.
2021_pipes2Solidnotworkingin2022.dyn (15.4 KB)
2021_Dyn_pipeto3DSolid.dwg (1.8 MB)
Kulkul
2
Hi @Udo
Welcome to Dynamo Forum!
That’s because Geometry Scaling was set to ExtraLarge. Make sure you set to Medium:
Udo
3
Thanks a lot. “Large” is working as well
“Medium” is from 0.0001 to 10.000 units
10.000 means 10000 or 10 ?
My pipes are longer then 10 (meter)
KirkWM
4
Thanks for showing where the new location for this setting
Do not trust Large, always pick Medium
