I was trying to use SamplelineByStation Node from Civil 3D toolkit, but cant figure out how it works. I have bellow doubt at well …
1.How to define the width of sample line using this node?
2. Is it possible to create a cogo points at intersection of sample line and feature line using dynamo? which node should i be using.
Thanks for support.
am i missing something ?
Thanks Paolo for the reply,
I am sorry for my basic knoweledge of Dynamo but done lot search and not able to find a way to get a geometry of featureline. can you please help with that part please …
i have reached upto fiding plane and featurelines…
Test_31-05-20.dyn (35.2 KB)
Use the CorridorFeatureLine.PolyCurve node.
@mzjensen Thanks alot for the help …i was getting some error about “unable to create line. points are likely coincidental” but changing the geometry range solved it.
@Paolo_Emilio_Serra1 …thanks for the support.
Glad to hear. Please mark a solution so others can find it.
