Same script not working
Hello guys, what are the reasons why dynamo script don’t work? Even if its a correct script?
Too many to count really, as ‘a correct script’ is a unicorn - all automations require a consistent environment and base to work consistently.
You need to be more specific to get help beyond check your Illudium Q-36 Explosive Space Modulator.
having trouble running a script on my PC that worked fine on another system. I’ve checked environments, libraries, and permissions, but I can’t pinpoint the issue. Any insights or guidance would be greatly appreciated.
Need to see what the error is. Otherwise we are evaluating why your Illudium Q-36 Explosive Space Modulator isn’t working, as everything is imaginary.
Can i invite you for a meeting if possible online
Not unless you have a consulting agreement in place for such calls already. I cannot give away services to some while other companies pay for for such access.
Open it in Dynamo.
Do you have any warnings?
Have you got all the packages?
Are there any red blocks?
If yes - fix them
Run the script
Are there any yellow blocks?
If yes, check the errors and fix them.
Check the output nodes - what are they doing and are they getting the correct inputs?
Finally, pray to the Dynamo Gods for forgiveness.
Found your error?
