Run single node multiple times with different values
Hi everyone :wink:
I´ve got a question concerning the execution of a node.
I´ve got a list of views and a list of dwg-filepaths which I want to input into a node which is called “Link DWG” from the Genious Loci Package.
When inserting the whole list I run into problems which the node. I had the same problems with other Nodes where I had to adjust the Python Script to match my List Structure. When inserting the Values one by one through x[0], x[1]… everything works perfectly fine.
For that reason I thought about the possibility to loop through my values one by one without changing the Link DWG node.
Does anyone know how this could work?
Thank and kind regards,
Jannis
Would you be able to post either your full .dyn file or a screenshot showing more context of how the data looks like before being fed into the Link DWG node? This is most likely related to lacing and/or levels.
Definitely list lacing and levels.
Sorry… It was a stupid question :wink: The node worked, but the result wasn´t as expected…
