Hi!
I’m trying to use the node “LinkDwg.AtOrigin” of Morpheus package for a link multiple DWG in diferent views. I’m a beginner user of dynamo.
I’ve prepared an excel with all views on first column and all file paths in the second one.
So, I’ve imported data to dynamo, I’ve create two lists, file paths and vides, but when I run the rutine I get an error, and I don’t know why.
If I punt only one file path anda one view, rutine works perfectly. But I need to link several DWG…
Could you help me!?
Thank you!
Hi @ariviti6 ,
Try with the longest lacing
(Right click on LinkDWG node and change the lacing).
Don’t work. Then the error is:
AG_dwg to revit.dyn (24.9 KB)
Hello…not sure but you feed in a string in your view have tried with views ?
try view by name from genius loci…
Thank you @sovitek , using “view by name”, rutine links all dwg file into the revit model, and put them into selected views.
Thank you! I have so much for learn!
Tim.r
September 18, 2025, 4:38pm
6
@sovitek This is seems to be broken in Revit 2026. Is there another node that does link to view ?
Just to confirm it works fine R22; 23; 24 it doesnt work in 25 or 26
sovitek
September 19, 2025, 4:32am
7
Hi @Tim.r it should work in 25-26 as well, but need ironpyhon installed , work both with 2.7 and 3.0
sovitek
September 19, 2025, 5:02am
8
and with pythonnet 3..
import traceback
import os
clr.AddReference("RevitAPI")
def linkdwg(fpath, doc, view, pin_link, this_view_only, black_and_white, units_str):
if not fpath or not os.path.exists(fpath):
return None, f"Invalid path: {fpath}"
options = DWGImportOptions()
options.AutoCorrectAlmostVHLines = True
options.ColorMode = ImportColorMode.BlackAndWhite if black_and_white else ImportColorMode.Preserved
options.OrientToView = True
options.ThisViewOnly = not this_view_only
options.VisibleLayersOnly = True
units = str(units_str).lower() if units_str else ""
if units == "foot": options.Unit = ImportUnit.Foot
elif units == "inch": options.Unit = ImportUnit.Inch
elif units == "meter": options.Unit = ImportUnit.Meter
elif units == "centimeter": options.Unit = ImportUnit.Centimeter
elif units == "millimeter": options.Unit = ImportUnit.Millimeter
else: options.Unit = ImportUnit.Default
options.Placement = ImportPlacement.Origin
try:
link_instance, link_result = ImportInstance.Create(doc, view, fpath, options)
if link_instance is None or not link_instance.IsValidObject:
return None, f"Failed to link: {fpath}"
link_instance.Pinned = pin_link
return link_instance, f"Linked successfully: {fpath}"
except Exception as e:
return None, f"Error linking {fpath}: {str(e)}"
try:
dwg_files = IN[0] if isinstance(IN[0], list) else [IN[0]]
dwg_files = [f for f in dwg_files if f]
if not dwg_files:
OUT = "No valid DWG file paths provided"
views_input = IN[1] if isinstance(IN[1], list) else [IN[1]]
views = [v for v in UnwrapElement(views_input) if v]
if not views:
OUT = "No valid views provided"
pin_link = bool(IN[2]) if IN[2] is not None else False
this_view_only = bool(IN[4]) if IN[4] is not None else True
black_and_white = bool(IN[5]) if IN[5] is not None else False
units_str = IN[6] if IN[6] else ""
if len(views) == 1 and len(dwg_files) > 1:
views = views * len(dwg_files)
elif len(dwg_files) == 1 and len(views) > 1:
dwg_files = dwg_files * len(views)
if len(dwg_files) != len(views):
OUT = f"Error: number of views ({len(views)}) does not match number of DWG files ({len(dwg_files)})"
links = []
logs = []
if IN[3]:
wstable = doc.GetWorksetTable()
activewsid = wstable.GetActiveWorksetId()
wsid = WorksetId(IN[3].Id)
WorksetTable.SetActiveWorksetId(wstable, wsid)
activewsid = None
for fpath, view in zip(dwg_files, views):
link, log = linkdwg(fpath, doc, view, pin_link, this_view_only, black_and_white, units_str)
if link: links.append(link)
logs.append(log)
if activewsid:
WorksetTable.SetActiveWorksetId(wstable, activewsid)
OUT = (links, logs)
except Exception:
OUT = traceback.format_exc()
finally:
Tim.r
September 19, 2025, 1:22pm
9
I have this Simpson Doh! moment now, Thanks @sovitek
sovitek
September 19, 2025, 1:25pm
10
yeah i always have that here, thats why the forum is so great
Tim.r
September 19, 2025, 1:49pm
11
Thank you, this is even better. Regarding the previous script; If I have a list of levels and I would like to add cad to each correspoding level, could I create a similar list in codeblock and point to File path, instead of manually pointing to them?
sovitek
September 19, 2025, 1:54pm
12
not sure havent tried, please create a new post with that ,s
