Hello, are there any constraints with respect to the round node with digit for “Small” numbers
Rounding rules seem broken
I’m on Revit 2020
edit: it’s the ending 05 or 25 (whatever the size of the number)
Cordially
christian.stan
I’m on Revit 2020
Cordially
christian.stan
not sure if this is what causes the issue but Python rounds away from zero and C# rounds to the nearest even number
It’s a specificity of IronPython2.7 (or a bug, fixed in Ipy3)
You can use Python3 or System.Math.Round() instead
in your examples under 2.7 you have the correct rounding
on the other hand not in the 3.4
odd.
I will use python for rounding from now on (with nodes or designscript it doesn’t fit)
edit: the probability of ending up at 3 significant digits after calculations for rounding to 2 digits should be very very low (Don’t waste energy, I found a workaround)
Cordially
christian.stan
