Round a number to nearest in a given range
Good morning,
I found a solution to round a number to the nearest in a range of values, is there a custom node and/or a more efficient DesignScript or Python solution
Forum english 24 juillet 2023.dyn (31.7 KB)
Thanking you in advance
cordially
christian.stan
Design Script:
sorted = List.Sort(List.AddItemToEnd(values@L1<1>, range));
indx = List.IndexOf(sorted@L2<1>, values@L1<1>);
indexes = List.Transpose([indx - 1, indx, indx + 1]);
set = List.GetItemAtIndex(sorted@L2<1>, indexes@L2<1>);
val = List.GetItemAtIndex(set@L2<1>, 1);
prior = List.GetItemAtIndex(set@L2<1>, 0);
next = List.GetItemAtIndex(set@L2<1>, 2);
mappedValues = (((val - prior) < (next - val) ? prior : next));
Works by adding the item into the list, and getting the value proceeding and following it, and finding which has less offset from the two. You do get an error if you provide a value outside of the limits of the range though, but that is good in some cases as it’d be outside your design limits.
Thanks mate, brilliant as usual
I enclose a python solution realized with great difficulty
import sys
import math
lst_values=IN[0]
lst_r=IN[1]
containerP=[]
for i in lst_values:
    val=[abs(j-i) for j in lst_r]
    print(val)
    val.index(min(val))
    containerP.append(lst_r[val.index(min(val))])
OUT = containerP
Cordially
christian.stan
Here’s my CPython solution for good measure:
valuesToMap = IN[0]
range = IN[1]
remapped = []
for v in valuesToMap:
    i = 0
    while True:
        if range[i]>=v:
            result = [range[i-1], range[i]]
            break
        i+=1
    dist= [abs(v-j) for j in result]
    if dist[0] == dist[1]: net = result[1]
    else: net = [i[1] for i in sorted(zip(dist,result))][0]
    remapped.append(net)
OUT = remapped
Works by iterating over the list of values until it finds a value which it is equal to or less than the current value, getting the item at the previous index, and taking the shortest of the two distances. There was an edge case around matching values (your doubled 0 value) which I used as a 1:1 setup, and I didn’t test for values outside the limits of the list.
There is one other solution based on geometry which might be worth considering, but I’ll let your brain think that over. :slight_smile:
I don’t know if you were thinking of that for the geometric approach :wink:
cordially
christian.stan
One method. Another would be to draw a surface on the YZ plane arrayed along the X axis and converted to a polysurface, create points along the X axis, use a closest point to node and pull the X value from there.
I would not have thought of it to be honest, you scocht me, speaking of that it’s time to throw a little behind the collar (Apéro time)
have a nice (day: 0 night: 1)
cordially
christian.stan
Hi @christian.stan & @jacob.small ,
What about this approach?
def round_to_nearest(input_list, target_list):
    if not isinstance(input_list, list):
        input_list = [input_list]
    result = []
    for num in input_list:
        nearest = min(target_list, key=lambda x: abs(x - num))
        result.append(nearest)
    if len(result) == 1:
        return result[0]
    return result
input_list = IN[0]
target_list = IN[1]
OUT = round_to_nearest(input_list, target_list)
Thank you Mr. Daan :wink:
cordially
christian.stan
