Hi everyone!!! I am doing a simply column with a beam in Revit, but I want that the beam rotates around itself, when I change values in Dynamo…the problem is when I connect all things in Dynamo…it appears message in Dynamo like that: Advertencia: Element.Error en la operación SetParameterByName (Error) in the node of Element.SetParameterByName …Could anyone help me???
The links of Revit and Dynamo:
Revit:https://drive.google.com/file/d/0B7BHQ9xNT7pWa21UVG90TlJCVHc/view?usp=sharing
Dynamo:https://drive.google.com/file/d/0B7BHQ9xNT7pWYTJHSjh4c0ZDZGc/view?usp=sharing
Thanks a lot!!!
Kinds regards!!!
@juanjose.gutierrez Rotate is not an available parameter
You’ll need to feed in an existing parameter name (such as Start Level Offset, yz Justification …) into Element.SetParameterByName
Ohhhhhh!!!Thanks a lot…I’m new in Dynamo…and I don’t know how it works…so good!!! Thanks!!
Regards!!!
