MelleH
June 13, 2023, 8:20pm
1
Hey,
I am trying to rotate the section view. The view, not the section element.
My current section:
The result i want is to rotate the view 180 degrees like shown below.
With my current script i am rotating the section element and not the view.
Thanks!
Current script:
I created a section. Fill some parameters and am now trying to rotate the view.
Get the crop region of the view and rotate that. I believe the post below covers it.
Hi Everyone,
I just wonder if anyone come across this idea before, due to my work I have to keep rotate and line up views in sheet. is it anyway we can rotate selected view with Dynamo? The rotate on sheet of Revit is very poor command, I usually have activate every single views then select crop view visible then rotate it. Is there any node or routine to allow rotate selected views?
Thanks for reading
Vinh
Here is code to rotate the crop region. It requires you to provide the crop region, a rotation axis line and the rotation degrees in radians.
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import XYZ, Line, ElementTransformUtils
crpreg = UnwrapElement(IN[0])
angle = IN[1]
line_axis = UnwrapElement(IN[2])
rot = []
crId = crpreg.Id
axis = line_axis.ToRevitType()
ElementTransformUtils.RotateElement(doc, crId, axis, angle)
OUT = crpreg,angle
MelleH
June 14, 2023, 7:18am
4
Thanks for your reply,]
But i dont seem to get it to work…
I think i am messing up with the line axis
I want to rotate it around its own axis
Hi @MelleH …this element rotate you show in first image is that one from genius loci, because that one should work i think…
MelleH
June 14, 2023, 8:42am
6
Hey,
I tried that, but it just rotates the section.
I think i found a workaround tho!
I rotate the view and the I reapply the cropbox.
I believe the code I provided is similar to what the rhythm node is doing. But since you have it working with rhythm, that’s will be the best option.
FYI, for the axis line, you need to get a center point of the view and the view direction and use that with line by start point and direction. We only use the tool on assembly views. So to get a good center point of the view, I get a bounding box of the element in the view and the center point of the bounding box. This pretty much forces the view to stay in the exact same place. I also reset the crop region after the view has been rotated. This is mainly for when the view has been rotated 90 degrees.
