Rotate section box to align with a selected face
iam trying to rotate the section box to be align with a selected face but iam a beginner
Crumple nodes has the View.SectionBox node which can retrieve the current box (note: this is not the CropBox) - Using the bounding box you can convert it to cuboid geometry and manipulate. Use coordinate systems to do this - then extract the max and min points and convert to new bounding box before utilising a Clockwork View3D.SetSectionBox node
Hi @yinodo2737
you select a top face or side face ?
Maybe this post will help you.
thanks it worked
but not exactly the way i wanted, i want to select a face then the sectionbox becomes parallel to that face
ty
i built the correct boundingbox as seen in 3dview but the node from cloclwork doesnt fit the sectionbox to the newboundingbox
I don’t know which type of face you selected (vertical or horizontal), but we can only rotate a sectionbox along the Z-axis.
its a horizontal face
yes i want to rotate the section box around z axis to fit the created bounding box
here is an example
same_for_agree
# Import RevitAPI
clr.AddReference("RevitAPI")
def set_SectionBox(view3d, ds_bbx):
    current_box = view3d.GetSectionBox()
    center_box = (current_box.Min + current_box.Max) / 2
    cs = ds_bbx.ContextCoordinateSystem
    tf = Transform.Identity
    tf.BasisX  = cs.XAxis.ToXyz()
    tf.BasisY  = cs.YAxis.ToXyz()
    tf.BasisZ  = XYZ.BasisZ #coord_system.ZAxis.ToXyz()
    tf.Origin  = cs.Origin.ToXyz()
    newbox = BoundingBoxXYZ()
    newbox.Max = current_box.Max
    newbox.Min = current_box.Min
    newbox.Transform = tf
    view3d.SetSectionBox(newbox)
views = UnwrapElement(IN[0])
ds_bboxes = IN[1]
if isinstance(IN[0], list):
    if isinstance(IN[1], list): OUT = [set_SectionBox(x, y) for x, y in zip(views, ds_bboxes)]
    else: OUT = [set_SectionBox(x, ds_bboxes) for x in views]
    if isinstance(IN[1], list): OUT = set_SectionBox(views, ds_bboxes[0])
    else: OUT = set_SectionBox(views, ds_bboxes)
OUT = views
Worked flawlessly thanks
