Rotate 3D Views from dynamo
Hi All,
I’ve been trying to find a way of modifying the orientation of a 3D view from Dynamo but couldn’t how.
is there a way to access that command from dynamo?
Thanks,
Perspective or isometric?
This is a node for creating and setting a perspective:
And this post contains some python code for the isometric:
http://dynamobim.org/forums/topic/view-orientation-and-python-script-refresh/
I believe that Python code could be modified with some of the info here to make the tool you are after:
For perspective views, there’s also a Clockwork node called PerspectiveView.OrientToEyeAndTargetPosition.
