Rotate 3d isometric View
Hello everyone! Is there any way to rotate an existing 3d isometric view?. I have found the means to modify perspective views, but it doesn’t suit me.
It seems like the solution lies somewhere in DesignScript language or in Python. But i couldn’t find any specifications with system functions to set values in (view3d.orientation. etc.), either i noticed, sometimes people are using such functions in code blocks and it works.
Here i found some API, but i don’t understand how to translate it to Dynamo languages.
https://thebuildingcoder.typepad.com/blog/2013/04/setting-up-your-vieworientation3d.html
It seems to be a solution, but what if I need my view to be set by specified vector? For instance, if i’ve got a set of coordinates (i am not fluent in Python :upside_down_face:)
This should be very useful for creation animations. Thanks for any help :smiley:
Hey,
So, we can change a 3D view by vector like this… (thanks to RIE)
I suspect that you want more control, in which case you need 3 things… An origin, a direction to look and an Up direction…
Unfortunately we can’t extract a ‘target’ from a 3D view, I don’t think… we can’t find the ‘centre’.
So if we change the direction, we will look at something else… which isn’t what you want…
For an animation, that might not be a problem, you would naturally get a location point, create your Eye, Look Direction and Up, then use the location point to create new Eye and Directions…
#From Ben Osborne
#http://dynamobim.org/forums/topic/view-orientation-and-python-script-refresh/
clr.AddReference('RevitAPI')
#we need to unwrap Dynamo 'elements'
view = UnwrapElement(IN[0])
#we need to convert Dynamo Vectors & Points to Revit XYZs
forward = IN[1].ToRevitType()
eye = IN[2].ToRevitType()
up = IN[3].ToRevitType()
#start transaction
#unlock view
view.Unlock()
#get up direction
#up = view.GetOrientation().UpDirection
#create a new orientation object based on our modified info
viewOrientation = ViewOrientation3D(eye, up, forward)
view.SetOrientation(viewOrientation)
#finish transaction
OUT = view
Hope that helps,
Mark
Woooooooooow this is great, thank you! maybe you’ve got some specification with all commands and systm functions?
Umm… there’s a few places… Maybe these are useful?
https://apidocs.co/apps/revit/2019/d795a238-fc24-1875-e64f-a2bef56ae949.htm
Why dynamo give IndexError: list Index out of range ['File "<string>", line25, in <module>\n']
