Room tags script not working
Good morning. I am new to Dynamo, was wondering if someone could help me with why this script isnt working.
Kind regards,
Your node called FamilyInstance.Room does not get information about the room elements of your fire alarm devices. I suggest you check if your room elements are encapsulating your family instance or not. Sometimes room elements are not reaching to the top of the space.
You can check element intersect with room
Refer like this.
I checked this and they seem to be ok.
This is a great script but nothing is intersecting. There are some rooms which are missing a room bound but I have just added them in. Furthermore checked sectional view too.
Spaces are generally used in MEP models, @ANJ do you use rooms or spaces?
We currently use rooms but Im aware of the spaces which is something which we are implementing. If I generate spaces would I be able to tag them the same name as the room names?
Yes, this is a native Revit feature (assuming the architectural model is linked).
