I am looking to create a room tag that lists multiple rooms. We have a typical floor plan for floors 4-6 so I’m wondering if there is a way to edit the labels in the room tag to display the various room numbers for different floors.
See below:
See below:
You’ll have to create shared parameters for rooms that contain the same rooms numbers and add these parameters to your tag.
After that, you will have to retrieve these room numbers and push them into these parameters.
Hello
Thank you for response. Does your solution also correspond to rooms on various levels? How would I retrieve and pull these room numbers from the various levels into a single floor plan?
So you want to fill this “ROOM” in Room Name and “B402” in Room Number ? is this what you’re looking for?
