Room outline from room geometry (referenced file with seperated facade)
Hi everyone :slight_smile:
I have some rooms which appear as closed room objects in my view. When using the node “Room.FinishBoundary” or “Room.Boundardies” I receive these lines:
Unfortunately, I need the closed polycurve which around the shown room.
I think about getting the Element.Geometry of the room and making a section with the Element-Level-Plane. But is there a better way?
The geometry I receive is faulty, because I get the room from a referenced file, which has a referenced facade.
In the normal document with the referenced facade the Node Room.FinishBoundaries works fine…
This should solve your problem.
Awesome :slight_smile: Thanks a lot steven. Works like a charm :slight_smile:
