You can get that location with the API.
Here is a python script that will:
- Check if the family has a spatial element point (green dot)
- if it does have it, it will return the “green dot” location.
- if not it will return the default family location (origin).
and the python script: (copy and paste in a python node)
# provided by johnp of sixtysecondrevit.com
# python template from clockwork
def GetLocation(item):
# if it has a calculation point return that
if item.HasSpatialElementCalculationPoint : return item.GetSpatialElementCalculationPoint().ToPoint()
# if not return the regular location
elif item.Location.GetType().ToString().Contains("LocationPoint") : return item.Location.Point.ToPoint()
else: return None
items = UnwrapElement(IN[0])
if isinstance(IN[0], list): OUT = [GetLocation(x) for x in items]
else: OUT = GetLocation(items)
