Hi all, I use a node from Archilab-net which allow me to get Element from linked file in room. The dynamo works perfectly but i would like to custom it.
By default, the script get take the family location point. Is there any way to use the Room calculation Point instead ?
i’ve try using this but without result.
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
rvtLink = UnwrapElement(IN[2])
transform = rvtLink.GetTotalTransform()
def FamiliesInRoom(_room, _families, _transform):
outList = []
for family in _families:
#pt = _transform.OfPoint(family.Location.Point) -> from the original script
pt = family.GetSpatialElementCalculationPoint()
if _room.IsPointInRoom(pt):
outList.append(family)
return outList
families = []
for i in IN[0]:
families.append(UnwrapElement(i))
rooms = []
for i in IN[1]:
if UnwrapElement(i).Area > 0:
rooms.append(UnwrapElement(i))
outData = [[] for i in range(len(rooms))]
for index, room in enumerate(rooms):
outData[index].extend(FamiliesInRoom(room, families, transform))
OUT = outData
Can someone help plz ?
thx by advance
