I would like to know how to select a linked room in the floor plan view.
I also want to be able to handle it like Select Model Elements using Dynamo Player.
Any solutions?
Hello
here an alternative with Revit API (Room’s Category must be visible in Visibility Graphics)
import sys
import System
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB.Architecture import *
from Autodesk.Revit.UI.Selection import *
class CustomLinkRoomSelection(ISelectionFilter):
def AllowElement(self, e):
return True
def AllowReference(self, refer, point):
rvtlnkInstance = doc.GetElement(refer)
docLink = rvtlnkInstance.GetLinkDocument()
elemLink = docLink.GetElement(refer.LinkedElementId)
if elemLink.Category.Id.IntegerValue == BuiltInCategory.OST_Rooms.value__ :
return True
return False
TaskDialog.Show('Selection', ' Select a link Room')
refElemRoom = uidoc.Selection.PickObject(ObjectType.LinkedElement, CustomLinkRoomSelection(), "Select a link Room")
rvtlnkInstance = doc.GetElement(refElemRoom)
elemLink = docLink.GetElement(refElemRoom.LinkedElementId)
OUT = elemLink
