Hi All,
First of all I have had a look through the forum and I have found some things that have allowed me to get this far but it keeps crashing and I don’t why.
Also the other methods create one elevation marker for each wall. What I am trying to achieve is one elevation marker in the center of the room and then four elevations of each wall.
Can anyone see any problems with the code?
I have attached to Revit file to the Dropbox link below.
PS. It is late here in UK I will check this post again in morning.
creating room elevations - debugging #9 (TOPOST).dyn (78.8 KB)
#Copyright(c) 2016 www.Learndynamo.com
#Please contact at jeremy@learndynamo.com
clr.AddReference('RevitAPI')
from math import *
# create varible for revit document
ponts = UnwrapElement(IN[0])
vertln = UnwrapElement(IN[1])
viewType = UnwrapElement(IN[2])
angl = UnwrapElement(IN[3])
vues = UnwrapElement(IN[4])
toggle = IN[5]
#pt = UnwrapElement(IN[3])
cenpos = []
lst = []
topponts = []
if toggle == True:
# start transaction
# code that modifies revit database goes here
for pt, ang, vln, v, cen in zip(ponts, angl, vertln, vues, cenpos):
elevationPT = pt.ToXyz()
eleMarker = ElevationMarker.CreateElevationMarker(doc, viewType.Id, elevationPT, 100)
#ele = eleMarker.CreateElevation(doc, v.Id , 0)
#ele = eleMarker.CreateElevation(doc, v.Id , 1)
#ele = eleMarker.CreateElevation(doc, v.Id , 2)
#ele = eleMarker.CreateElevation(doc, v.Id , 3)
lst.append(eleMarker)
#Rotate elevation marker towars model line.
#ElementTransformUtils.RotateElement(doc, eleMarker.Id, vln, ang)
#end transaction
lst.append("set to true")
OUT = lst
