I searching for the Block ,Room.BoundingElements-ArchiLab
Somebody take them??
But my Bibliothek is empty
I think it’s now called Room.Boundaries or something similar. You can also try to use the filter function at the top right of the package browser to search only in Archi-Lab.
Edit: the node you are looking for is in Chynamo
oh yes!
thanks for information
Do you know, what about
Element.Level-Clockwork
See Chynamo also
negativ
Two options: wether Chynamo (type “element levels”) or Clockwork directly
You will need to take a look at the warning to see what’s wrong. You should also verify that your elements have an associated level (try Get Parameter Value By Name with “Level” as parameter)
