Hello, this node from the package works good. It works perfectly if the voltage parameter is a type. In the family that I have been working on, ampacity, voltage and number of poles are instance parameters. So, after running this node, number of poles and ampacity stay as entered, but voltage becomes zero. Anyone who worked with this node, any idea why would it set voltage to zero?
Related topics
| Dynamo script causes families instance parameter to become read only | 2 | 1033 | June 22, 2018 | |
| Electrical Voltage Parameters - Need help with Voltage Values | 6 | 2782 | February 11, 2018 | |
| Accessing the "Volts" parameter | 2 | 413 | June 19, 2016 | |
| Element.SetParameterByName setting similar, but wrong values into specified fields | 2 | 712 | April 23, 2018 | |
| Element.GetParameterValueByName returns incorrect value | 3 | 1016 | November 22, 2016 |
