Hi right now I’m trying to use a dynamo node/python script to circuit electrical devices, the problem I’m having is the script causes my electrical devices voltage parameter from the electrical connector to set to zero and become ready only. The only way I’ve found around this problem is to edit my parameters voltage from instance to a type parameter which prevents the parameter from resetting to zero and becoming read only, but I really need my families voltage parameter to be an instance parameter or else it seriously complicates the work flow I was trying to achieve does anyone have any ideas how to fix this? I posted the nodes code below and a link to the dynamo forum discussion where the python code was developed any advice on solving this is welcome please.
clr.AddReference(‘RevitNodes’)
clr.AddReference(‘RevitAPI’)
from Autodesk.Revit.DB.Electrical import *
from Autodesk.Revit.DB import MEPSystem
clr.AddReference(‘DSCoreNodes’)
import DSCore
from DSCore.List import *
import sys
pyt_path = r’C:\Program Files (x86)\IronPython 2.7\Lib’
sys.path.append(pyt_path)
/# Import List ( ICollection(ElementId) = ListElementId )
clr.AddReference(“System”)
def tolist(obj):
if isinstance(obj, list):
return UnwrapElement(obj)
return [UnwrapElement(obj)]
input = tolist(IN[0])
electComponents = ListElementId
for i in input:
electComponents.Add(i.Id)
app = uiapp.Application
C=0
OUT=
for i in electComponents:
b=electComponents[C]
bb=tolist(b)
newcircuit = ElectricalSystem.Create(doc, bb, ElectricalSystemType.PowerCircuit)
C+=1
OUT.append(newcircuit)
