Hi all,
I have this code which works fine with the select model element node but the problem is it doesn’t work with a dyno button/dynamo player.
So I searched the forum and I came across a post that suggested to use the pick model elements from the rhythm package. I’ve seen a GIF that Mostafa posted and I thought this will solve my problem, but unfortunately the node treats model spline lines differently to the select model elements node (see Below)
The select model elements spits out points at parameter on continuous spline,wheres the pick model elements doesn’t.
As always, the comments are apprecitated.
Thanks in advance
