my code below:
test= 1
runs[2].LookupParameter('Extend Below Riser Base').Set(test)
Result:
How to avoid revitapi to auto convert the length?
my code below:
test= 1
Result:
@newshunhk I guess by dividing the input by 304.8 ![]()
my current unit is sometimes millimeter or meter depends on project, dividing 304.8 is not always correct.
You can look up the project units for a specific unit type, Length in the code below, and use that to determine the conversion needed.
clr.AddReference('RevitAPI')
unitType = UnitType.UT_Length
currentDisplayUnits = doc.GetUnits().GetFormatOptions(unitType).DisplayUnits
OUT = currentDisplayUnits
thank you!
and I found that your code is for revit 2021 and previous,
I need a different one if using revit 2022
You need SpecTypeId instead of UnitType because of a change in the API between 2021 <->2022:
if int(DocumentManager.Instance.CurrentUIApplication.Application.VersionNumber) < 2021:
factor = UnitUtils.ConvertToInternalUnits(304.8,doc.GetUnits().GetFormatOptions(UnitType.UT_Length).DisplayUnits)
factor = UnitUtils.ConvertToInternalUnits(304.8,doc.GetUnits().GetFormatOptions(SpecTypeId.Length).GetUnitTypeId())
Here another example:
unit = famdoc.GetUnits()
currectformat = doc.GetUnits().GetFormatOptions(UnitType.UT_Length)
accuracy = currectformat.Accuracy
unit.SetFormatOptions(UnitType.UT_Length,FormatOptions(currectformat.DisplayUnits,accuracy))
famdoc.SetUnits(unit)
currectformat = doc.GetUnits().GetFormatOptions(SpecTypeId.Length)
unit.SetFormatOptions(SpecTypeId.Length,currectformat)
thank you!
