in revit2021 dynamo… there is no error
but in revit2023 dynamo… below - error…
how can i fix below error message…
thank you
I assume it is related to this post.
Thank you for your reply..
I changed dynamo node to Python Script..
after that error is disappeared..
Below is Dynamo and.. My Python Script..
import sys
#Select element from revit.
def set_parameter_by_name(element, parameterName, value):
element.LookupParameter(parameterName).Set(value)
lst0 = UnwrapElement(IN[0])
lst1 = IN[1]
lst2 = IN[2]
#Start Transaction
for lvl2, val2 in enumerate(lst0):
for lvl1, val1 in enumerate(lst0[lvl2]):
#Set a new Comment
set_parameter_by_name(val1, lst1, lst2)
OUT = lst0
Thank you
