Line to structural beam
I AM TREATING TO CREATE BEAMS FROM IMPORTED LINES TO THE REVIT FROM AUTOCAD, I MAKE A SMALL CODE WHICH WORKS ME WHEN I DO IT ALL IN ONE TIME, BUT WHEN I WANT TO DO THEM BY PARTS (SEPARATING BY DIMENSIONS) I REMOVE SOME THOSE I HAVE PREVIOUSLY DELETED, THAT’S WHAT I SHOULD DO, THANK YOU.
Close the script between runs, use Dynamo player to force a close between runs, or use transactions as a means of breaking the link between Dynamo and the newly created elements.
See here:
Also caps lock isn’t your friend.
Apparently closing the application, and I do not have that inconvenience, and I’m sorry for the capital letters, I forget to use the translator.
