Revit Python Wrapper / RPS Dynamo Python Node
Hi All,
I am looking to install Revit Python Shell but I am wondering if I do it will it cause some of my existing Dynamo scripts containing Python Nodes to stop working.
I want to know if installing the Revit Python Shell will effect the way I need to write python in the Dynamo Python Node?
Thanks, Simon
It shouldn’t affect any existing code you have in Dynamo, although the way code is written in RPW is slightly different. For example, in Dynamo:
clr.AddReference('RevitAPI')
from Autodesk.Revit import DB
And in RPW:
from rpw import DB
