Revit & Metamorphosis
Hi all,
I have been testing the Metamorphosis add-in for Revit (which is amazing) but I am having issues with the Dynamo script. Unfortunately my Dynamo experience jsnt extensive enough to work it out.
Here is a link to the add-in
The issue I am having is the script feeds back a ton of warnings and deprecated nodes.
I am currently using Revit 2016 and Dynamo 1.2.0.
Could this be a version thing?
Any help is appreciated.
Try uploading another screenshot. Perhaps with the built in screenshot tool?
Hi Andrew, I can tell by your screenshot that you are missing the DynamoJson package. Other packages you need to have installed are Clockwork for Dynamo 1.x and Archi-lab_Mandrill. See if the definition works after you download those packages and run it again.
Thanks Kyle,
That worked brilliantly. Much appreciated.
Hi all,
I have similar problem that @Andrew_Harp had. I have the packages mentioned by @Kyle_Martin but still is giving me some errors.
I’m using Revit 2018 and Dyanmo 2.0.1
Any help is much appreciated
