Archi-lab_Mandrill Create Report node
Hi, I am trying to visualize some data from the “METAMORPHOSIS” - An Open Source Revit Change Analysis Tool”, it´s a tool for comparing Revit projects versions.
http://www.martinportfolio.com/blog/2017/1/25/aec-technology-hackathon-2016
The work flow consists on a plug-in that compares and generates a json file with the changes. Then using a dynamo graph and the mandrill package nodes we can visualize the data of the Jason report.
When doing the charts, the final nodes in my graph are these
And when I launch, the mandrill window is empty.
Does anyone knows why this isn´t working?
One thing i find strange is that the node(create report) in the example is different from the node I have in my graph.
Using help on the node it seems that this node as no output
But in the exemple the node create report seems to have an output
Has the node changed ?
If anyone could help me with this questions I would be much appreciated,
Regards
Hi Joao,
Do you use Dynamo 1.3 or 2.0 ? Can you verify the version of your Mandrill package ?
The last update is 2019.2.0.
It should look like to this :
report
This could also be due to a conflict with a Revit plugin.
My dynamo version is 1.3 (I think?)
And I installed the lastest version of the package
And my create report node looks like this
For Dynamo 1.3 version, install Archi-lab_Mandrill 2018.0.2.
This should solve your issue.
I had to install the 2017.12.4 version, but it worked
Thak you very much!
Ps: by the way, how can i update to dynamo 2.0?
I’m glad it worked.
You can download Dynamo 2.0.2 on this webpage https://dynamobim.org/download/ under Dynamo for Revit.
