Build a small sample of the data - say an rvt with the necessary families, and just one room and the associated xls info. Post them here (or to another file sharing service) so we can have a look. My gut says that you need to use a face at point method (clockwork I believe) after you project the points into the Revit elements. Also confirm that you can manually place the light fixtures at these locations.
Dear Jacob,
I’m sending You the next files:
- RVT file
- DWG plan (exported from rvt)
- DATA EXTRACTION xls file (extracted from the dwg plan)
- LIGHTING FAMILY (one of them that we should use)
- DYNAMO PROCESS FILE (that finds projected points on the ceiling, but places families on floor).
Note that I created sone generic mass ceilings (because we’re dealing with those kind of ceilings in the architect’s IFC that we received).
Please let me know what I’m missing …
DOWNLOAD LINK:
https://drive.google.com/drive/folders/1qCTs4TVHlUME-bxCXMq9X4RYlkX74Y1G?usp=sharing
thank You a lot!!
Matija
Hi @jacob.small ,
I made similar script.
I successfully combined the two scripts. From cad linked get the center point location and place a family from ceiling surfaces. I have 3 ceilings with different offset when I run dynamo only 1 ceiling is in correct hosting and offset the rest is not hosted and a little off to specified ceiling offset. Please Help!
Dear Tarcok, the video was very very helpful…
We added some modiffications to the script and made it work perfectly…
Thank everybody for Your help!!
I’m sending You the final script hoping to help somebody with a simmilar request/problem
Download link:
https://drive.google.com/drive/folders/1YZGGHV5XJP9tAAnqQG5Oj4MwNJpXT_ii?usp=sharing
cheers
Matija
