Revit Family Parameters Value "Family Editor"
Someone @Kulkul @craig @Einar_Raknes could write the final code for reading the parameter value. Because i’m trying this and of course returns me the parameter name, not the value:
# Import RevitAPI
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import FamilyManager
pl = doc.FamilyManager.Parameters
Name_Parameter = IN[0]
for p in pl:
	a = p.Definition.Name
	if a == Name_Parameter:
		OUT = p.Definition.Name
@Raul.Galdran
Thanks a lot Kulkul, the solution is working for number parameters!
@Kulkul the solutions is not working for text parameter. You know why this could happen?
Hi @Raul.Galdran ,
this should handle all parameter types :
# Import RevitAPI
clr.AddReference('RevitAPI')
s = doc.FamilyManager.CurrentType
p = [i for i in pl if i.Definition.Name == Name_Parameter][0]
try:
	v = s.AsString(p)
except:
	try :
		v = s.AsValueString(p)
	except :
		try:
			v = s.AsDouble(p)
		except:
			v = s.AsInteger(p)
OUT = v
I tried your code and at least for me doesn’t work with Length Parameters:
The one up is yours. And the one down is mine, yesterday i managed to find a way. Still needs a little bit of work so it can read all type of parameter but at least can read text and length parameters. I’ll like also integer and number but i think is just adding a little bit more of code.
i copy the final code, is a little bit bungler but works:
# Import RevitAPI
mm=304.8
for p in pl:
		paramType = p.Definition.ParameterType
		if paramType.ToString() == "Length":
			OUT = s.AsDouble(p)*mm
			OUT = s.AsString(p)
Thanks all for your ideas and your time
My bad @Raul.Galdran , when the parameter type is not right for the query method, I thought it would return an exception but it just returns “None”…
So here’s an alternative to make sure all parameter types are handeled :
# Import RevitAPI
UIunits = p.DisplayUnitType
vals = s.AsString(p), UnitUtils.ConvertFromInternalUnits(s.AsDouble(p),UIunits), s.AsInteger(p)
v = [v for v in vals if v != None]
OUT = v
I also added some code to get the current UI units in your family document and do the convetion automatically. That way all units will be handeled automatically.
@Mostafa_El_Ayoubi
I tried your last code and still doesn’t read text neither integer. I’ve modified " in a really crappy way" but now works with every Parameter Type i’ve tried. ( Text, integer, number, area, length, and several units more), all returned the value from the parameter.
The problem was (UIunits = p.DisplayUnitType) in text/integer…!
I copy the final code:
# Import RevitAPI
try:
	vals = UnitUtils.ConvertFromInternalUnits(s.AsDouble(p),UIunits), s.AsInteger(p)
	v = [v for v in vals if v != None][0]
	OUT = v
except Exception:
	vals = s.AsString(p), s.AsInteger(p)
	OUT = v
Thanks again for your time and solutions
