Revit assembly views dimensioning
I have 300+ assembly of precast panels in Revit.
I would like insert the view in sheet & dimension the views.
Dynamo is a good option I feel. But How to do it, can some one kindly guide me on this ?
Thanks.
Hello… try this one for place on sheet…for dimension i will suggest to take a look at Genius Loci package, there is a lot of nodes for dimension…
Thank you so much Søren. I am novice to Dynamo & I am not familiar with its terminologies. Can you please just me any good tutorial for a Quick start to understand your answers?
Thanks heaps.
You are welcome…
Try to take a look here: https://primer.dynamobim.org/ and Dynamo Dictionary if you take a search here on this forum on assembly, there should come a lot of hits…Good luck /Søren
Thank you Soren. I will do that.
