I saw the coincidence that where the assembly instances that are packed in same assembly type, they are composed by the same families with same orientation, but in other location of the project, so how to force to be each assembly instance to be in independent assembly type is the question. the codes shared for renaming work well so that was already resolved. I created new post to continue this: How to force Revit to create each assembly instance with separate assembly type
