I need to update to Revit 2022 (from 2019). I use a Dynamo script to access the core width of the walls - It works i 2019. I use Clockworks CompoundStructureLayers, but the width now returns Null. All the other functions in the node work.
Is there an alternative to Clockworks node or anything I can do to make it work?
The picture is from Revit 2019.
Can this change be the reason? https://archi-lab.net/handling-the-revit-2022-unit-changes/
Hi @jpe,
You can use the Get CompoundStructureLayers node of the Genius Loci package instead.
It is updated for Revit 2022.
Thanks, you saved my day
Thank you too! Was getting crazy since an hour, as Clockwork used to work like a charm
