Retrieving all instances of a wall type (Python)
Hi All,
I’m referring to the solution of this post by @Jeremy_Tammik
https://forums.autodesk.com/t5/revit-api-forum/selecting-all-instances-of-a-wall-or-are-there-any-instances-in/m-p/4938760/highlight/true
WallType X;
FilteredElementCollector allWallsOfTypeX
  = new FilteredElementCollector(doc)
    .OfClass(typeof(Wall))
    .Where( e => e.WallType.Id.IntegerValue.Equals( X.Id.IntegerValue ) );
Is there a filter (slow or quick) that can be used to replace the last line (Linq) ?
I’ve tried using the following;
FamilyInstanceFilter(doc, Brick230Id)
but I get an error;
Tried that, but it looks like the FamilyInstanceFilter only works with loadable families. It makes sense as System families don’t inherit from FamilySymbol:
Regarding if there is another filter for that purpose, I think what is in there is quite nice.
I haven’t tried a logical filter, but it may work. Although I don’t think it would make the code shorter:
https://www.revitapidocs.com/2020/3b8d6b55-0cab-1810-1188-840800e5eaa2.htm
@architectcoding Thank you for your reply.
Not sure how you were thinking of making the logical filter work as you have to provide quick/slow filters. See sample code below from @Jeremy_Tammik Github.
      ElementClassFilter f1
        = new ElementClassFilter(
          typeof( FamilyInstance ) );
      ElementCategoryFilter f2
        = new ElementCategoryFilter(
          BuiltInCategory.OST_Doors );
      ElementCategoryFilter f3
          BuiltInCategory.OST_Windows );
      LogicalOrFilter f4
        = new LogicalOrFilter( f2, f3 );
      LogicalAndFilter f5
        = new LogicalAndFilter( f1, f4 );
My bad, though a combination of those filters would yield something, but have tried it and it is not working. In the end I have to use some combination of methods to retrieve those instances as Jeremy did.
Yes, the last line can be replaced by a quick filter. You can use a parameter filter. That line is checking the value of the WallType element id. The wall type element id is also accessible from a built-in parameter. So, you can set up a parameter filter that checks for equality with the target wall type element id.
does this work?
FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls).WhereElementIsElementType().ToElements()
FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls).WhereElementIsElementType().ToElementIds()
Thanks @Jeremy_Tammik !
I found 2 solutions as shown below.
Option1:
pvp = ParameterValueProvider(ElementId(BuiltInParameter.ELEM_TYPE_PARAM))
fRule = FilterElementIdRule(pvp, FilterNumericEquals(), Brick230.Id)
filter = ElementParameterFilter(fRule)
Brick230Instances = FilteredElementCollector(doc)\
					.OfClass(Wall)\
					.WherePasses(filter)\
					.ToElements()
Option 2
fRule = List[FilterRule]()
ParId = ElementId(BuiltInParameter.ELEM_TYPE_PARAM)
fRule.Add(ParameterFilterRuleFactory.CreateEqualsRule(ParId, Brick230.Id))
					.OfClass(Wall)\
					.ToElements()
@stillgotme Your code will just retrieve all WallTypes in your project. I’m after instances of a certain wall type.
ops. misunderstood your question :smiley:
eletypes =  FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls).WhereElementIsElementType().ToElements()
elety = [eletype for eletype in eletypes  if eletype.Name == "Brick230" ]
eles = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls). WhereElementIsNotElementType.ToElements()
neweles = [ele for ele in eles if ele.GetTypeId() == type.Id ]
can try something like this too :slight_smile:
Thanks @stillgotme! but the point was if it could have been done with a slow/quick filter (not list comprehension) :wink:
ahhh, well the set of solution you provided was new to me too :wink:! im still learning new things everyday! Thanks for sharing
Brilliant! Both look good to me.
gotta say this line of codes are damn useful too, i just used it in this application:
pipes = ToList(IN[0])
pipeIds = [p.Id for p in pipes]
pipeIDS = List[ElementId](pipeIds)
ParId = ElementId(BuiltInParameter.RBS_PIPING_SYSTEM_TYPE_PARAM)
fRule.Add(ParameterFilterRuleFactory.CreateContainsRule(ParId, "Sewerage",False))
filteredpipe = FilteredElementCollector(doc,pipeIDS).WherePasses(filter).ToElements()
to filtered out required system type pipes. Once again thank you for this sample of codes @salvatoredragotta
Not a problem and thank you for sharing your sample code :grinning:
hi , i’m trying to get all of wall types those are exist in “Wall types” node(Dynamo) alltogether, not only those are exist in my revit project , can you help me about that ?
i’ve already have Python in my dynamo . is there any code that i should copy ?
Thank’s
No need for Python.
Element Types (Choose Wall Types) and a All Elements of Type Node should do it.
Thank you I really appreciate your help !
Hello again :slight_smile: i wanna know can you help me in doing the same process for windows (instead Wall Types) ?
