Retrieve the dwg file from an ImportInstance
I’m trying to retrieve the DR01.dwg file (unlinked) from a file.
I managed to find the name and category names of this file.
import sys
instance=UnwrapElement(IN[0])
doc=instance.Document
scat=instance.Category.SubCategories
lname=[doc.GetElement(c.Id).Name for c in scat]
OUT = instance.IsLinked,instance.LookupParameter("Nom").AsString(),type(doc.GetElement(instance.GetTypeId())),lname
Do we have to do a DWG export of all the objects belonging to these categories? I looked before posting.Perhaps there is an easier approach.
Thank you in advance.
Sincerely,
Christian.stan
An export won’t even get all the data - things are lost once they are brought into Revit.
Best bet will be to identify the original path and see if you can track down that file.
Hello and thank you.
In light of your comment and this one on a similar topic,
Similar topic
the only solution is to export the view to DWG with only the isolated instance imported.
Sincerely,
Christian.stan
