Hi Everybody,
I am getting only string value, but i require both string and double value.
can anybody advise the procedure?
#Copyright(c) 2015, Konrad Sobon
# @arch_laboratory, http://archi-lab.net
import sys
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
import re
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
keySchedule = UnwrapElement(IN[0])
data = IN[1]
inputParams = IN[2]
upper = IN[3]
# "Start" the transaction
tableData = keySchedule.GetTableData()
sectionData = tableData.GetSectionData(SectionType.Body)
keyNames = []
for i in range(1,sectionData.NumberOfRows - 1,1):
keyNames.append(str(int(i)))
allKeys = FilteredElementCollector(doc).WhereElementIsNotElementType()
params = [[] for i in range(len(keyNames))]
test = []
for key in allKeys:
try:
if key.get_Parameter(BuiltInParameter.REF_TABLE_ELEM_NAME).AsString() in keyNames and key.OwnerViewId == keySchedule.Id:
indexValue = keyNames.index(key.get_Parameter(BuiltInParameter.REF_TABLE_ELEM_NAME).AsString())
for i in range(0, len(inputParams),1):
params[indexValue].extend(key.GetParameters(str(inputParams[i])))
except:
pass
for i, j in zip(params, data):
for param, value in zip(i,j):
if isinstance(value, str):
valueDecoded = value.decode('string_escape')
if value == None:
valueDecoded = " "
valueDecoded = str(value).decode('string_escape')
if upper:
valueDecoded = valueDecoded.upper()
param.Set(valueDecoded)
# "End" the transaction
#Assign your output to the OUT variable
OUT = keySchedule
