Hihi! I’m currently trying create a script that can automatic export my layout plans to pdf. and it was running smoothly until it shows that I have errors in my script, I’ve tried many ways to change ard but its still the same error and I’m not so sure what can I do with it..if anyone knows please help! thank u!
Hello @nicole_wong_you_en and welcome
where does that node comes from ? probably you need the right ironpython package installed as well, but you could try this one here if it is better ![]()
Home.dyn (7.6 KB)
arhh EDIT you feed in a categori guess it should be a family type [titleblock]
i’ve tried it! it helped!! tysm!!!
