Replacing parameters NAME (not value) inside families
Hello!
I was wondering if there is a way to replace parameters inside families. Say I have a shared parameter called “A1” and I need to replace it by the “B2” shared parameter. I managed to change its values but I found no way to replace the parameters names.
Thanks!
Eduardo Tavares
you can replace one parameter with another one
you need to have a prepared files with shared parameters with which you are going to replace the current ones
